no output on mix 3 and 4
I have two mixs going to my video camera. Up until now all worked well. Mix 3 I have no input to my camera. I switched cable from the board to my camera to mix 2 and the cables send the signal when flipped. I have no idea why I am suddenly not receiving my mix 3. I also have mix 4 which goes to two rear speaker. They no longer work either.
This is for a church I attend. I really need to figure out why neither mix is working as they were working
Thank you for any help you can give me
What mixer ? Most likely someone messed up your settings. Do your mix 3 and 4 meters show signal and can you hear it when PAFL’d ?
Giga
It is a QU 32 need to try your ideas later today
I assume your connecting to the mixer outputs and not a stage box.
Could be…
-All of the send levels are turned down
-The mix masters are muted
-Some or all of the input channels have been un assigned from mix 3 & 4.
To check that select mix 3 and then hold down the assign button on the left side of mixer, the green SEL buttons will light up on the channels assigned to the mix, if not
keep holding the assign button and hit the SEL channel buttons to assign the channels.
  • As Giga mentioned check the metering and PAFL on the mixes.
Are there various scenes saved and used on your mixer?
