So I pre-programmed a show with my SQ5 and 2 x DX168. At the venue I had to put the two stage boxes at the opposite side of what I expected, so I patched channel 1-16 to stage box 2 (ch 17-32) and channel 17-32 to Stage box 1 (ch 1-16). What then happened is that I got no sound on the first 4 channels on Stage box 2. re-routed 1 to 1 and every channel worked again. I am 100% sure I have patched correct, and I also tried to patch other channels to those preamps, with no luck. Any suggestions why this happened?
I’m always 100% shure… but sometimes I make mistakes…
Yep, I’m 100% sure. I checked again now, and I am actually not able to patch anything to channels 1,2 and 4 from DX168. Local inputs work. It’s not a hardware problem, it’s only in this show file. But I’d like to know why this happened, and if I can fix it. It’s a pretty extensive show file, so I’d like to keep it.
