When recording or playback with qu-drive, access to USB key generates noise in the headphone (each time the led lits, there is a sound in the headphone). What does it come from, is it possible to fix it ?
Probably same as QuDrive/ST3 interference.
In fact it may well be ST3, have you checked?
Thank you for your tip, I just tried out and it didn’t solve the problem.
Noise appears exactly when the led is on.
I’ll guess at same root cause, different symptom then…
I have noticed a similar noise on several Mix outputs of my QU-32 while recording using qu-drive on a thumb drive. And yes, it does look like it coincides with the flickering record light near the thumb drive connection. It’s a slight fluttering noise, almost a ticking but not quite a tick. I had just filed a support ticket before I saw this post.
@[XAP]Bob : you were right, I tried again and it’s OK.
First time, I only plugged in ST3 a cable with a passive DI at the other end, the noise was still there.
Then, I plugged a cable with a MP3 player : no more noise
(I’ll try a stereo plug with tip and ring connected to sleeve)
Hmm, isn’t turning down ST3 volume or muting sufficient? Assigning ST3 input to dSnake or QuDrive should also cure that symptom.
@Andreas : You’re right, as was [XAP]Bob in his first reply. I didn’t check that ST3 was on, with fader at 0dB. With fader down, no more noise. Sorry to bother you with a pb already known. I hope it will help other users.
(Really pleased to have this Qu-16, but I have to get used to it…)
