Hello everyone,
Do you know how to accurately determine the level of a fader?
Thank you
Hello everyone,
Thank you
You can see the numerical readout from the fader by selecting the channel, pressing Routing and then touching the Main LR section of the channel strip. There’s a dB readout on-screen.
It might also depend on what you need it for.
For example, you can also see the values in the MixPad when moving the faders, or in the app Mixing Station.
Thank you. In the SQ Routing, the value is not precise, is it possible to have at least one digit after the decimal point?
This suggests that two or three decimal places would be still better.
And now I’m even more curious about what use cases would require something like this. )
if the strips dynamically change from ch name to level and back when moving or touching the fader, that would be great.
But please only as a deactivatable option!
And by the way, SQ doesn’t have touch-sensitive faders.
So they would need at least a tiny movement.
I wanted to copy the level of one fader to another, but I can’t find the option, so…
It’s not exactly what you mean, but the suggestion to copy the routing (so also the positions of faders) of an input channel has been around for a long time, but unfortunately hasn’t yet reached the hearts of the people who could implement it.
yes, a little fiddle would be necessary. just had the idea, cause i use it quite often on a hd96 if i need a quick and handy check where i actually am (also channel wise)
