It appears that you can only assign an even number of mono busses when setting up the mixer. I can’t, for example, have 1 mono group and 5 mono auxes, the minimum is 2 mono groups and either 4 or 6 mono auxes.
This might be a limitation if trying to use the mixer to its full capacity. Can this be changed?
+1 for me!
Another idea, more “experimental”: 8 effects are too many in most of “small to mid-size” situations; it would be great if in the resource page there was the ability to exchange an fx unit with 1 or 2 output mixes.
Just dreaming? …
regards
Massimo
It’s possible on the ilive range to choose how many mono/stereo effect you want. It’s in the configuration page.
I suppose it would be the same on the GLD
The reason you have to assign in pairs is the DSP architecture. that’s hardware an cannot be changed.
Lieven
T112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver
yes, but if you don’t want to use all 8 of them, you cannot free some additional resource to add more mix outputs.
But I think it’s a matter of DSP architecture too, so it’s just too “experimental” [
regards
Massimo
That’s right , you can free buses but not mix Outputs.
Has also to do with the DSP architecture.
Lieven
