Anyone know how to stop this. Seems our musicians can mute themselves from the house mix when they want. Everything is disabled in permissions. Is there another location to turn this option off in the t-112.
It’s the wrong place to ask this…
But I don’t understand the question
gesendet mit Tapatalk
The Mute button is only visible in the My Mix layer. This layer is intended for channels dedicated to monitoring purposes (split channels). I wouldn’t recommend putting any FoH channel in this layer.
Thank you. Already changing.
It seems that the channel mutes can appear in any layer if enabled. To do this, press Setup (on the Right-hand pane) and a small side-bar will open up on the right side of the lower window. When pressed, the lower window will flip, showing the “Custom Layer Channel Processing and Mute button”.
-Mark
Thank you
