When I connect the USB to Windows 10 I see “SQ Speaker” as a sound card.
I want to send the audio from different programs to different channels.
Is it possible to create multiple virtual sound cards or is this only possible via Dante?
Have you installed the Windows ASIO / WDM Driver?
https://www.allen-heath.com/key-series/sq/sq-software/
Hmmmm - no a direct link it seems - I’m sure you’ll find it from there though…
Thank you Mark, I did check it and yes I have the ASIOTM/WDM driver installed, also the latest firmware of the SQ5.
I will probably work when using prologic or cakewalk but what I want to do is use 3 different programs:
Spotify with the equalify plugin: Set to “SQ Speaker 1”
Karafun: Set to “SQ Speaker 2”
KaraokeMedia: Set to “SQ Speaker 3”
PC Sound (Youtube): Set to “SQ Speaker 4”
On the mixer I can set the USB-B to different channels but in my PC I only have one option, that is “SQ Speaker”
As I’m not a regular PC user, I have no suggestions, and don’t even know if what you want is possible. I suspect it may not be.
Hopefully a PC user will help you.
