Optional input switch to SD when playing multitrack
Happy user here. The CQ18T usability is awesome!
Use case: Record and replay multitracks right away using the CQ18T like a tape player.
It would be very nice to have an option to automatically switch the recorded channels to SD when pressing play and to switch to analog input when pressing record. This would avoid having to go back to the config menu, select the inputs and configure them every time one goes from record to playback.
Definitely not something for all multitrack record/play use cases hence the need for an system option.
Thanks for listening.
You could just create a scene for that purpose?
I could. But it would still require multiple steps to switch from one scene to the other.
I am using Soft Key 1 for Multi track record/stop and Soft Key 2 for Playback/Pause. Recording and Play would be one key press away with the option to switch inputs from analog to SD and back.
+1
Actually missed this post when I posted a similar but more detailed suggestion here: https://community.allen-heath.com/forums/topic/input-source-setting-for-multitrack-playback
Sorry for the double post!
