Graduating from the Behringer X32 to a new Allen & Heath Avantis this Summer.
I have volunteers on my church production team and therefore need to take away guesswork on some settings. Using the X32, there was a whole slew of support for OSC Commands into the device. Therefore, sending commands to mute faders, and do slow crossfades through QLab software was never a problem.
How can I send automation commands to an Avantis using QLab software?
Hi Steve,
Check out our DAW Control driver: https://www.allen-heath.com/daw-control/
Not yet tested and supported on Avantis, but it will be soon.
DAW Control will create virtual MIDI ports on your computer and provides several maps for different applications, including a ‘CC Translator’ map that can be used to automate Input or Mix channels from QLab with individual crossfades, mutes etc.
I appreciate and understand the MIDI protocol for DAW Control.
What I am looking to do is send OSC Commands so that I can declare things like, “Unmute Channel 16 Fader” as one type of OSC Command but also send commands like this “Start from 0 and raise the fader to -10dB over 5 sec” This is possible to send with QLab over OSC Commands. I just need to know where I can get the list of OSC Commands like I used with Behringer products.
We don’t support OSC. However the functions you are describing can both be achieved with the DAW Control driver.
The fader automation can be set in QLab either by using the MIDI Thru map and the NRPN fader level messages (as described in the MIDI protocol for dLive and soon to be published for Avantis), or by using the CC Translator map which should make mapping easier and multiple channel fades possible at the same time.
If you need help programming QLab, open a ticket at support.allen-heath.com and our Support team will be happy to assist.
Is there a reason as to why Allen and Heath won’t implement OSC support. I find it much easier to implement with the more human friendly sintax. OSC has become an industry standard in the theatre world for this reason- especially as show automation becomes more complex using programs like QLab
