Out to telephone and/or FaceTime or Skype
Hi all,
Anyone have any experience or suggestions for best way getting an audio line out to an iPhone (for a cell call) and or out to a computer or phone for audio to Skype or FaceTime, and even internet broadcast.
Suggestions for cables and path would be great.
Can I even just send just the LR channels out via USB to an iPad for broadcast?
Any experience or advice for this would be appreciated
The Apple Lighning > USB camera lead (+ a regular USB type B) should work - you can get stereo or even multiple tracks to/from a QU iPhone or iPad with it.
I’ve not actually tried it with Skype etc, but I’d be surprised if it didn’t work, as it’s worked with everything I have tried so far.
Thanks Mark. We’ll give it a try.
Provided that your iPhone has a headphone jack you can use that to send analog audio into the phone. The headphone jack is a TRRS / tip ring ring sleeve. The tip and the ring closest to the tip are headphone outs the ring next to the sleeve is the mic input. It is a mic level input so you will need to pad the input. I made up a cable so the client at an event I do a couple times a year could stream it on Facebook live with a direct audio feed. You can find the headphone jack pin outs on line. The same pin outs also work on most Android devices.
I’ve done Skype off mixers using a PC before - no issues with a line in.
Using a phone should be very similar, just watch your levels.
You can buy 3.5mm TRRS → dual 3.5mm TRS cables which may make life easier.
