Outboard insert LR not possible v1.4?
Hi, I need to insert main LR a external graphic eq in the surface sockets like I did in first GLD firmware versions, and now with v1.4 I can’t do it. When I try to assign inputs and output sockets, for example:
Send/Output Sockets/ 21 & 22
Return/Input Sockets/41 & 42
When I press Apply, the Sockets changes automatically to dSNAKES 1&2 In and Out, and the I/O screen channels change from Main Ins1 to Unasigned.
Mix editor works with this error too. dSNAKE Exp out shows at 8 channels! and 16 IN! I can’t understand. I’m desperate.
Please, help, it’s urgent. Band engineer wants it! Thanks
Don’t hold your breath on that one. I doubt most anyone can tell the difference anymore in DSP processed GEQ and a hardware box. If he is that picky, patch through it before it hits the crossover, amps whatever. Who says it has to be on an insert?
Can you confirm your firmware version? The Insert screen display bug was fixed in firmware V1.41.
Hope this helps.
Hi Nicola! thanks, was this, I didn’t know that this bug and new 1.41 version.
I take the opportunity to say that when insert outboard in a channel or LR, have a little noise, like a pink noise, even when connecting directly out to in shockets by XLR, without outboard, make it noise. Can compare on/off buttom insert. Maybe due to the preamps?
GCumbee, I’m agree, but many engineers prefers work with by external graphic or comes with some compressors to insert. I use a digital snake, then, I do not want to carry 2 xlr cables to the stage!
