Output Hiss - QU-16
I’ve recently taken delivery of a QU-16 Chrome as my first digital mixer and I’ve got it set up at home to learn as much about it as I can. It seems to have a very noticeable hiss and I just want to see what anyone else thinks about it before I declare it faulty.
I’m using a Bose S1 powered speaker, in battery mode, with the bluetooth turned off, and with both other gains turned to 0. The channel I’m using is set to halfway.
I’ve got nothing connected to any inputs on the QU-16 right now, and I’ve got all the input channels (1-16) muted. I also have the L/R channel muted too.
When I connect the desk to the speaker via a balanced XLR cable, I get a loud static-type hiss from the speaker. Disconnecting the cable stops the hiss.
I’ve tried a 20M cable, a 10M cable and a 0.5M cable, just in case it was a faulty one, but I get the same static hiss each time, and it goes away when I pull the cable from the desk.
Any suggestions would be useful - especially as I try and get used to this desk.
I’ve also tried connecting to Mix 1, Mix 2, etc and get the same hiss no matter which output I use.
Could it be my mains supply, do you think (Mixer is on a fully earthed supply)? Or is it more likely a fault on the desk itself. Or is it something I’ve stupidly missed?
Meant to say - Unmuting the L/R channel makes no difference to the hiss volume.
Things to check:
  • tone generator
  • is the hiss also present in the headphone out
  • try another outlet (incl the Bose)
  • can you see the signal on the meters
Good luck !
Giga
Hello @Incandescence,
I would recommend you try a different pair of speakers to disregard any possibility of the noise coming from the speaker side.
Regarding the suggestions from Giga just above, I would also recommend performing a Hard Reset of the mixer to make sure all settings are back to fabric state and disregard any possibility of having a tone generator active or any other setting that could cause this or any other potential issue.
Steps for Hard Reset can be found on page 84 of the user guide: https://www.allen-heath.com/media/Qu-Mixer-Reference-Guide-AP9372_10.pdf
If after this you still encounter the same behaviour, please submit a ticket with our support centre at: support@allen-heath.com
Thank you!
Rafael
@Giga
Tone Generator is off.
Hiss NOT present in headphones unless I turn them all the way to Max volume which is normal
Outlets changed around the house & workshop to test - no difference
NO signal present on any meters either “real LED” or on the touch screen Levels or RTA pages
@Rafael A&H
I’ve just hard-reset the mixer, which made no difference.
I’d also tried using a larger pair of speakers with a separate amplifier and ground-lifted the amp in case. The result is the same in all cases.
Just to be sure, I’ve now unplugged the QU-16 and grabbed my old Behringer analogue to plug in and test. It’s definitely not the cables or speaker - the hiss is coming from the QU-16.
I’ve put a (bad quality - sorry) video of the issue online so you can hear the difference between plugged and unplugged:
YouTube Video Here
Maybe check that your xlr cables do not have pin 1 jumpered to the shell of the connector. I have ran into strange noise issues and have found that the XLR cable
had pin 1 tied to the outer shell of the connector, easy to check by opening up the connector.
Some equipment that will cause an issue others not so much.
Hello @incandescence,
If this is a hardware failure it will require service of the unit.
Please submit a ticket with our support centre to follow up and advise how to proceed, at: support@allen-heath.com
Thank you,
Rafael
Thanks everyone - ticket submitted to A&H to investigate and get it fixed/replaced.
Great forums, by the way - I’ll certainly be hanging around to learn and help where I can.
Can anyone tell if the QU is still being manufactured. I have a QU16 Chrome and am looking at buying a backup. I have located one in a store in Dublin but its not a chrome edition They are telling me its 5 years old but I not sure if that’s true. Any thoughts please.
Yes the QU is still current.
The “Chrome Edition” is all in the firmware…and the later models had chrome caps on the faders.
If the 5 year old one works and is in good condition for a good price all it may need is a firmware update.
I actually bought a good clean used older QU16 with the black fader caps about 4 years ago that still was running the original firmware. I updated the firmware and it works great.
Hi Incandescence, how did you go with resolving this, did you find what was causing it? I have a Qu-16 with what appears yo be the same issue. Thanks, Ben
Did this just start with a system that has been working and nothing has changed?
If your connecting to powered speakers make sure the speaker input is set to line level not mic level.
What output on the mixer is has the issue?
Does it change with muting the inputs and the output master?
Hi Mike, thanks for getting back to me so quickly.
It’s a 2nd hand mixer I’ve just bought. Previous owner has not heard this noise. I did have a mic accidently feedback when I was initially testing it which made quite a loud sound and a pop noise through a speaker I had connected, I wonder if this has had any impact.
I’ll check the powered speaker is set to line level input tonight when I get home. I have used the speakers on their current settings with another system and no noise was present.
The noise is coming through all outputs. I’ll check the muting tonight to see if that changes it.
A technician has taken it apart to see if he can find the issue. Everything looked fine except that the voltage of the power supply was sitting at 8.73v. He adjusted down to 7.92v to see if that was causing the issue but the sound was still there.
We think it could have something to do with the main electronics board inside the mixer, so I’m looking to take into the Melbourne based technician listed on the Allen & Heath website to see if they can find the problem.
I’ll come back to you if muting is having an impact and will check the line level is set on the mixer.
Very keen to get this resolved, from the short time I was getting to know the setup of the mixer it seemed really easy to use and will make mixing in my band easier with the wireless access compared to the MixWiz I’ve been using (a great mixer though!).
Cheers,
Ben
Hi Mikec,
I’ve checked it tonight, the speaker is set to line level and the noise is coming through. Just to see what would happen, setting it to mic level increased the noise (appreciate this isn’t the correct setting for a powered speaker).
Correction to my earlier post, it’s the left and right main out only - the other outputs are fine.
The noise goes away if all the channels are muted. un-muting them one by one the noise gradually comes on. So all channels seem to be causing the noise.
The gain for each channel is set at 12 o’clock. if I adjust the gain of any channel up the noise increases.
Interested in your thoughts, thanks for your help.
Cheers,
Ben
Hi Mikec, also to say this is without any inputs connected to the mixer.
Cheers,
Ben
I did find the issue, and it turned out to be the powered speaker after all.
Sorry that doesn’t help you, but the guys at A&H Support were excellent and well worth contacting. Even if it’s a second-hand unit, they will have some troubleshooting ideas.
Cool no worries, thanks. glad you found the issue!
Cheers,
Ben
Gain up on open mic inputs will create noise, I have a QU16 but never tried that to see what the noise level is like.
Are the FX return channels turned down and or muted?
Are the channels all set flat on the EQ and all the channel processing bypassed?
Hi Mikec,
I’ve checked the FX return channels with level & mute and it didn’t impact the sound. I did notice that ST1, 2 & 3 inputs don’t have the sound. It’s only coming through when the main 16 channels are unmuted and levels are up. If you increase the gain on any of the channels the noise increases.
The EQ is turned off and all channel processing bypassed.
I checked the headphone output and there’s no sound there. Correction to an earlier note, there is noise on all the aux sends, 1-10.
I can only think it’s something to do with the gain or power supply on the 16 channels, but I’m not 100% on how it’s all wired below.
Cheers,
Ben
How does it sound with a mic plugged into a channel and giving the system some check 1 2’s?
