Hi, is it possible to manage the two L & R channels separately in output when playing an audio file (wav or aif), L in PA and R monitor? Thanks
As far as I know, you can’t split a stereo playback channel into L and R.
(Although I think the CQ only supports stereo WAV files from USB-A and not from the SD card anyway - but whatever.)
But you could split your stereo file into two mono tracks L and R, play these together from SD, and send them separately to the different Main LR and monitor mix.
And by the way, you can’t play AIF files anyway, only the specific WAV files, as described by A&H.
if it were like that it would be the best
