Output Routing
Understand Input Routing.
But is the Output also routable?
IE can I have an Input routed to Output 6 only. Then have Out 6 routed to main?
So that I dont have to use another Input to physically route it.
Short: no “routable”.
The routing are fixed, each input is routed to main and out 1-6 (and fx). You can choose levels. You can have input “i” into each out (for example input 1 into mains, out 1, out 2, out 3 and out 6).
Thanks.
Assumed but HOPED.
I will jump out to another input for now.
There’s a wish in the feature suggestion section for “split” the same input into different input channels. You can support the request…
There are also request for an I/O matrix (seems like there are limits to the number of different mixes, but maybe routing already processed input into different channels and outs could be doable…).
Was just about to post Routable Outputs as a suggestion.
Will look for the split suggestion first.
