PAFL & AMM in V2.11
Hello,
After updating to the newest release V2.11, when PAFL’ing an input ch that has its fader down with AMM enabled no audio is passed. Turning the AMM off allows audio to pass as normal
I should note that the surface is set to PAFL bus 2 and the AMM 1 has ch 1-36 engaged.
I experienced this as well the other day. I was stumped, but was jumping back and forth between artists and talking heads so I didn’t have time to investigate whether or not I was doing something wrong. What I also didn’t try doing was changing the pick point in the Mixrack>Audio>AMM section back and forth to see if it forces a change.
I also experienced this yesterday, but finding this post mid-show was reassuring. At first I removed the input from the AMM, but also just punching the AMM out does the trick for all the channels.
Hoper this get’s and update soon, but knowing the issue helps a lot allready.
Hello, i’m experiencing the same problem on a Dlive S5000 since the update.
It took me some time to understand that the problem with the PAFL was only on the channels linked with AMM on…
Anyway is there a way to fix this problem or do i have to downgrade to a previous version?
