PAFL bus and Metering
Hi
I’ve found what I believe to be a …inconsistent operational ‘feature’ and would be curious to hear if others feel the same…
the meters on the bottom left of the display… one would assume they are your main bus meters… but that only seems partially true… the Mono or Center is…and by that I mean there’s no way to influence that level from a control… but the left and right are directly related and controllable by the main PAFL audio settings/routing… I believe this to have been this way on Avantis and DLive and possibly iLive and GLD …forever… but I wonder if that couldn’t be …fixed?
I’d also love to see the PAFL bus expanded with a 3rd output for those configurations with LCR or LRM or anything that adds a 3rd bus… that could be patched to an output like the other PAFL outputs, understanding that the headphone jack might be required to do something crafty due to only being 2 channels…
what’s people think on that?
I’m not sure which meters you are referring to, but you might try going to Meters/Mix and then hold down the Options button to get to the Meters options page. If the metering point is set to Post Compressor (or anything other than Post Fader), try changing it to Post Fader and see if the behavior changes to what you’d like.
These meters, and these PAFL controls under setup/audio/pafl
Interestingly this was the topic of a recent chat I had with A&H support. It’s definitely a historic feature and can be seen on the GLD range of desks. I would absolutely assume those meters represent the main bus level (or LCR) when the console does not have an active PAFL. HOWEVER this isn’t the case, they actually represent the default monitor mix level that’s sent to your PAFL bus when no specific channel has been selected. I don’t really understand this philosophy, surely it was a decision at some point however I’d much rather see an untried master output level. I guess this falls down if you have configured your console with a “main” mix, whereas there’s always at least 1 PAFL bus?
