Hi there, I use SQ regularly in small broadcast environments and the following small updates would make SQ significantly better for integrating with external comms systems:
-Talkback monitoring directly to PAFL option (press talk and you hear it in PAFL if enabled)
-Ability to pan the EXT IN to PAFL source (I take Comms as an EXT IN to PAFL, but would love to have it just in one ear)
-Route internal busses to PAFL without Solo’ing (same as routing Ext In, I would like to have the option to build more complex Comms bus and then route that Bus to the PAFL, currently I work around that by using MainLR as my Monitor Bus and another Mix as my PGM out)
-Route Talkback to any port (unless I’m mistaken, you can only hard patch the Talk input to a port but not the Talkback with the Talk button in effect, it must be first routed to a Bus and then routed to a port)
Thank you!
