I’m looking for confirmation on the use of the PAFL buttons. It appears that the PAFL Button (i.e. ability to listen to a specific channel with headphones) is only valid when the LR Mix is selected. The PAFL for individual channels appears NOT to be usable for mixes other than the LR Mix. However, the PAFL on the Master channel does seem to follow the Mixes.
This does not seem to be very clear in the documentation, and I discovered this while trying to listen to a particular instrument input on a channel in a mix (7-8) that was going to a streaming computer. Unfortunately there was no need to run the instrument through the LR Mix as it had enough volume and breadth that it did not need any further volume / mixing in the room. So the fader in the LR mix was at min.
Am I missing a setting or is this how the PAFL is designed. If so, it seems to be a waste especially when doing multiple mixes.
the documentation was written as an engineers reference not a genuine users manual
you can listen to any channel on the headphones or any mix or combinations
you do have to select the mix and also pafl
we send out mix78 to the pc for livestreaming and adjust everything in it separately as well as a total mix for OBS to process
like Showtime noted - read the manual but then
look at one of the many videos that explain things more how to do things
than the manual does which is mostly stating that it can be done
UPDATE:
I ran a series of tests based on the comments. The key elements seem to be AFL output and AFL input. the other settings didn’t seem to do much.
With the AFL Input turned off, I heard the input by channel (channel PAFL selected) however the fader had no impact, regardless of mix selected, but I was able to hear the input as what seemed as pre fader / pre-PEQ (I may be off on the pre-PEQ, wasn’t able to really determine any changes when adjusting). when I selected the Master and adjusted the fader for a specific channel, the fader impacted the output. The comments seemed to imply that I can set the PAFL to a given mix and subsequently any applicable channel. I have yet to experience that. It seems that I can do that (adjust faders and impact sound) only when I’m in the LR mix. Every other mix is either dependent on the LR settings for a channel or the channel faders have no effect.
What I want is to be able to hear a single channel volume/FX in the headphones for a given mix - not just the LR mix. I’ve read the documentation and looked at the video, and they do not directly address this as far as I can see.
thanks
Doug
Not sure what the problem is you are describing. Exactly what is it you are trying to DO?
Look at the block diagram. Lower right side and see pfl and afl coming out.
See the pafl bus. See what goes into the bus.
Trace back to see where those come from.
You have to select what will come out the mix.
You set up the mix separately.
No mix is dependent on LR settings. Except that they also contain channel inputs that also go to the LR out.
Did you set afl and pfl on the main layer?
Did you push the mix button?
Did you then push the pafl button? Which one did you push?
You should hear just that mix.
Then use the faders and you can change what goes into the mix and hear it on the phones to verify you did change that channel.
If you just want to listen to one channel then you have to select that channel.
But you only hear that channel then, not the mix as it is now deselected.
Ok. Guess I wasn’t clear. Audio PAFL settings:
Input AFL off
Mix 7-8 selected.
Channel 6 PAFL selected. regardless of mix selected, same volume / sound heard,
however, faders had no effect.
Master fader selected in each mix, channel faders affected volume in headphones.
What I am trying to achieve is to hear a specific channel in a given mix in the headphones as I adjust the faders -i.e. channels 2-7 in Mix 7-8 independently via PAFL in the headphones. I would expect that when I select Mix 7-8 and then channel 5 PAFL, I can hear the change in sound as I adjust the fader. Unable to achieve that!
When I select the Master PAFL, then the channel fader has an affect! But at the Channel PAFL, no affect.
afaik you cant hear channel separately with the mix selected
you need to select that channel to hear what it is doing
else you select the mix and move that channel fader to see how it changes in the mix
What is Pafl on a mixer? Pre/After Fader Listen.
This allows you to hear a particular channel via the headphone output. You can bind a softkey to clearing any PAFL selected channels so that you can hear the final mix. It’s essentially a solo button, but only via the headphone out.
I think your pushing too many buttons. If you just want to hear the changes with in a mix in your headphones you just need need to hit PAFL on the selected mix not on the channels.
you can listen to one channel OR
you can listen to the mix and see how moving a given channel’s faders changes the mix
MikeC may have stated it clearer than I did earlier,
you cannot push both pafls and do what you want to do
select the mix and move the faders for the channel of interest to see how the mix changes
pretty sure that is exactly what I said before
do NOT select the pafl for one channel unless you just want to listen to that as solo
do NOT push both channel and mix and expect to get what you say you want
