So i have been staring at it an likely blind.
I am running a c3500 for foh controls. Using a touchscreen and Director on a computer for mixing live stream.
the FOH is controlling 1-64 channels, the touscreen computer is acting as a second surface and controlling 65-128 for Live stream recording.
I would like to be able to use PFL2 for our livestream mix position. Route it out of a local output from the surface. PAFL2 works with our touch screen and feeds out of a local socket output to a headphone amplifiers for Our livestream engineer to use
Any help appreciated
Jeff Flowers
I haven’t done exactly what you’re asking about, but I know you will need to have added any additional PAFL busses to the mix engine at:
Mix Rack → Config → Mixer Config.
Then the PAFL busses should appear for patching to wherever you need at the PAFL tab under:
I/O → Outputs
I don’t know director but I assume there is something similar to the surface setup to tell director which PAFL to use.
I found the following. It looks like the first answer from Nicola is using two surfaces, the next is using director. Hopefully that helps.
https://community.allen-heath.com/forums/topic/dual-independent-pafl-for-foh-and-monitor-engineer
Here’s where the option is for selecting control of a 2nd pafl bus in director (or another surface)
