Pan on matrices busses
I would like to see an option to set different output levels for Left and Right on a stereo Matrix.
Sometimes I’m using a stereo Matrix to feed speakers that are physically hung in different positions. Once the speakers are installed, it can be difficult to fine-tune the balance between them.
I would be happy with simply being able to have different gain levels for L and R, rather than having to use two separate mono Matrices.
This would be really useful for fine-tuning speaker levels after installation.
Until your feature suggestion is potentially implemented:
It might be helpful for you to know that in a stereo matrix, all sources have a pan control.
At the very least, in cases where a loudspeaker mix is ​​simply routed to a matrix, this control could, in principle, already provide the functionality you’ve suggested.
In more complex cases, the desired behavior could, at the very least, be replicated.
