Pan settings on FOH vs Aux busses.
Hello Experts
I am fairly new to using an expensive console like the dLive. I already looked at the reference guide and for some reason am getting lost so some guidance to my noob question will help, as I come from the analog mixer world.
Is the Pan setting for any input channel global i.e if I pan a channel to Hard-Left will it be that way for FOH (Mains) as well as any Auxes the channel is part of, OR can we set panning for channel separately for FOH (Mains) and Auxes ? i.e in this case the channel pans hard-Left for FOH (Mains) and if I want I could pan it Hard-Right for a specific Stereo Aux ? Is that functionality available ? or am I imagining too much ?
Yes, you can chose whether a stereo aux’ pan follows main pan, flips it L/R, or is independent.
Thank you so much for the quick response, patience and help. Would you know where exactly I could find instructions on this ?
Hunted it and found out. Its at ROUTING once I select that Aux and “Follow Main Pan”. Appreciate it.
How can I have a specific input pan left or right in an aux output? I’ve tried a few things, but nothing seems to work.
Select the Aux, got to the Routing page, on the top (iirc) are the Follow Main Pan and Flip Main Pan settings. Disable Follow Main Pan, then you should be able to pan channels into that Aux freely.
