we had some company fit an QU32 at church and did a general sound check.
All the mics seem fine apart from one lav mic (Sennheiser G3) which the vicar uses, The settings they did was fine just way too bassy and was hard to understand
I improved it (i just left it on blank with some changes) but it still seems overly quiet even with gain increased or doesn’t sound right
I’ve read the manual about the EQs and watched various videos but still seem confused by it all.
Does anyone have any dummy guides on what each knob does?
No one has complained, just doesn’t sound right to me
Any help would be grateful - i have posted an image of the current one
In all fairness the company who installed the mixer should have also included
some training on the mixer and go over how they configured it for your system.
Finding a good pro company/installer is the key.
As for the level on the lav mic what is the input level at the board on that channel?
Can you not get it any louder without feedback?
You may want to try cutting some in the area of 300hz, that said not knowing the rest of the system and configuration.
Vicar has mentioned them training us but they’re waiting until more people are interested so i don’t know when that will be
I don’t know the input levels for that channel but volume wise, i do it around 10 on the faders and Gain is on 12, any slightly louder then we start getting feedback
You to need to identify the first couple frequencies that feed back and cut/reduce those
on the lav channel EQ…or depending on the system maybe at the over all system eq.
The graphic EQ mode will show you the frequency area that is feeding back.
You stated that you were using a Sennheiser G3, but that system can be used with at least 3 Sennheiser mics, and they have drastically different frequency responses. I’d like to make some suggestions, but it would be helpful to me and others if you could tell us which mic is connected to the transmitter.
I have found cheaper mics to be very difficult to EQ & set up in church acoustics. The Sennheiser ME2 can often work quite well for live PA if the overall speakers have been tuned & then the EQ set for the mic itself. (Obviously, for an omni mic, volume level can not be as high as is achieveable with a close headset mic). I have found it easiest to start with graphic EQ to work through each band to see where the resonances fall. This can potentialy be translated on to paramateric EQ. I got a very stable setup using the SQ EQ.
I looked into specifics regarding the JK044 lavalier. I was unable to find information that jibed with your description of its performance. Most reviews of it were fairly positive.
In order to address your problem, a discussion more extensive than is typical on a forum like this is required, so I prepared a PDF for this purpose. It is attached, and hopefully will meet the file size restrictions imposed here.
Let me know if you need additional information or have specific questions.
Thanks for all the tips, i’ll have a look when im next at church, im not their next week
but it probably hasn’t helped how they positioned the speakers, the one on my side is about 5m infront of a TV Screen attached to a pillar so naturally the further back at church, everything sounds duller due to it bouncing off the screens on that side etc
There are many factors at play in a situation like this. That’s why I recommend you spend some time reviewing the resources I sent. It won’t be a waste of time.
If that will take too long, you should press the installer to help you work the issue.
Hi Chris, I have the Qu32 and our church recently purchased the Sennheiser EW-D ME2 Wireless Lavalier Microphone System. I am having a difficult time giving the microphone some body because I am getting some feedback. I will EQ the room via the GEQ and see what happens, but can you provide any tips I can utilize? Thanks
Use the EQ to notch out the feedback frequencies, try the parametric EQ you can dial it in to the frequency and adjust the notch width, push the system till it starts ringing use the parametric EQ, set up a notch of medium width, slide that notch around over the frequency area that is ringing / feeding back till you find the spot that stops it and maybe tighten up the notch some. Push the system a little higher till the next frequency starts to feedback and do the same thing. Cutting three or four frequencies will be about the best you can do.
Of course it helps if the sound system is properly installed for the room!
I tried that and will try again this week with more time. I will also raise the volume on the powered speakers (found out that they are less than half way), to see if that helps. Thanks
EQ’ing can be simple but most videos on the topic get complicated if you don’t know some basics. Here’s a start:
Low sounds are low frequences and high sounds are high frequencies.
Look at the PEW screen as 4 columns and 3 rows with an extra doo-hicky on the left end
Each of the 4 main column can raise/lower a band of frequences. The way it does this is like dipping a fishing net in water. The net has a shape and you can control how deep into the water you dip.
The bottom row affects the amount of increase/decrease made to the frequencies scooped up by the “net”
The middle row fine tunes (higher or lower) the frequencies scooped up. This means you can overlap with other columns
The top row changes the shape of the “net” that is grabbing frequencies
For a muddy or “bassy” voice, use the bottom row to increase the volume of frequencies in dark blue column until you hear a difference. Then use the top row to narrow the “net” until you hear a change. Back it off a little. Increase/decrease using the bottom row and/or fine tune the frequency affected (middle row) to taste. If you totally bugger it up, just make everything flat again. Rinse and repeat with the red frequencies
The doo-hickey on the left side is a High Pass Filter (HPF) control. It filters out all sounds starting going from low to high as you sweep across the screen. For males you can set it to 200. For Females, about 350. What you are doing is taking any room noise out of the equation so the PEQ can work on the voice.
