The small folk venue I volunteer at has an Allen and Heath PA12-CP powered console, with passive FOH speakers and monitors (one mix). I would like to get some live experience on my Qu-SB at that venue using their existing gear.
My goal is to patch/bridge my Qu-SB into the PA12-CP to mix shows, piggybacking on the PA12-CP amps to the unpowered speakers. From the PA12-CP manual I am not sure which inputs on the PA12-CP I should use for this. I am thinking I should be using the AB AMP inputs. NOTE: the PA12-CP amps are set to run mono… ampA to FOH and ampB to the single monitor feed.
From the PA 12 – CP manual I’m not 100% sure which inputs to use. I am thinking the A and B amp inputs (see attached image). From the Qu-SB, what outputs? L or R to ampA input (neither are labelled /Mono as you see in North America)? Mix 1 to the ampB input?
To be clear, I want to do all the mixing via the QU-SB, but run the outputs via the amps of the powered PA12-CP. And I assume I am missing some other required tweaks!
Thank you for any clear direction anyone can provide on this matter.
