I noticed during a gig last week that when in Processing mode, while mixing via iPad (MixPad 1.6.0), that when I select another input channel and then reselect the original IP, that both the Input and Output settings on the Peak Limiter 76 change to some other values on the iPad display, but they remain unchanged on the board. Therefore you don’t know which settings are in use.
When I make the slightest adjustment to either of these parameters on the iPad, the value on the board jumps to match that of the iPad. When I make the slightest adjustment to either parameter on the board, the value on the iPad jumps to match that of the board.
So the iPad and board are talking, but when switching between IP channels these Pk Lim76 become “lost” between the iPad and board.
When using the board only, all PK76 settings remain unchanged, as expected, when switching channels
I have photos if anyone is interested.
Firmware 1.6.0 4812
Still not fixed with latest 1.6.3 firmware. Very frustrating to pay for Peak Limiter 76 and not be able to use it via SQ MixPad on an iPad.
The Input and Output values shown on the iPad do not match those of the console when you switch (on iPad) from Channel X to channel Y and then back to Channel X.
Hi All, still venting about the fact that the 1176 compressor cannot be used via MixPad as the settings do not correspond to those displayed on the board.
Allen and Heath representative: Is it possible to get a refund for items we purchased yet are defective and unusable. Seems likeyou shouldn’t be taking money for things that don’t work.
MixPad did not work the last time I tried. A&H feels bad about it and it’s on the list.
After using Mixing Station for the last few jobs, I can’t see going back to the A+H app.
