If I tap the side mix buttons, no GEQ flip is available. I have to go to the layer and hit the sel button on the mix channel you want, to allow the GEQ flip. You should be able to select from the side mix button.
I can also see a situation where the sel is still on, but you’re not on that layer, and you have chosen a side mix button, and the the flip button. The PEQ will still be for the bus that was selected before.
This isn’t actually a bug, as you generally don’t want to automatic lose a Sel of a channel when making changes in a Mix.
Not necessarily. To achieve this, you can simply activate the Mix’s Sel button right above the Master fader.
From then on, Sel will also follow the Mix selected to the right - and so will an activated GEQ Fader Flip.
Excellent! Perfect.
Thanks.
