PEQ preset recall filter
Hello, I use the AHM16 with a Dante card as a system processor often. I’ve been using it with Custom Control to EQ my PA and drive my LRSF feeds for a while, I have two main features that are missing.
  1. would it be possible for the PEQ representation on Custom Control to have a pinch for the band Q? I use a knob under the screen for the width of each band but it would be great to allow either a “selected band” option when programming the knob on Custom Control or a pinch. Since the number of PEQ bands is fixed it could be a dropdown menu rather than a “input number” window and maybe it could allow a knob to be dedicated to the band selected. This way a three-knob design can be put into place?
  2. can the recall filter on the presets be expanded to insert the bypass button of the single bands or, if not possible, the bypass of the EQ? I’d like to be able to hear the PA without my EQ, and if I’m only using the ipad to control I then have limited control. When I am connected through AHM Editor then it’s way more flexible but I’d like to be able to bypass the EQ without having to make a flat preset and then I have to start from scratch.
Thank you in advance!
