PEQ under 200HZ
Hello,
I would like to know something about the PEQ. Is it possible for the first band to go above 200Hz?
I’m stuck below 200Hz for the first band of the PEQ. I’m using the latest version, V1.34, on the Avantis Solo
Thank you very much
There is a setting where you can have your EQ bands be “full range” or “limited”. It sounds like it is currently set for “limited”. If you touch and hold the Options button and then (while still holding the options button) touch anywhere on the PEQ screen, you will pull up the settings to change this functionality.
Check out page 13 of the Firmware Reference Guide for more information.
So many thanks, it’s working
