pfl/afl bounce back
Maybe there is a way to do this already but I don’t find it… It works this way with mains I think but that’s not that important to me.
I would really like a way to have priority levels or bounce back on pfl/afl so that if for example I am in a subgroup then pfl a channel within the group that as soon as I cancel that it goes right back to the subgroup I was in without needing to select it again. I find myself doing that manually all the time. I’ll listen to a group and jump through some of the channels within the group and go right back to see if the group now sounds like what I was after.
input PFL overrides mix AFL and switches back to the mix afl after deactivating the input PFL
You suggest I’m missing it but I know that works with a mix selected, but I don’t think that functions with a subgroup selected, maybe it does with DCA’s ?. We we still like to use subgroups and if the hierarchy was mix - subgroup/DCA - channel and it would bounce back upstream I would like that a lot. Am I missing something ?
mix or subgroup behave the same…
source (input) PFL overrides all mix AFL
at least that’s what I remember… will try later to confirm
