Hi All - I am getting the CQ-20b and would like to know if the following is possible.
I am the drummer plus sound person for the band. I would like to use the headphone out/jack as my mix to monitor the Main LR, but also use it to Solo/PFL the bands aux mixes so I can hear what they are hearing from the headphone out.
If so, how do you set that up and is it possible to hear the processing(eq, compression, fx) being applied as well then switch back to my Main LR mix? Kind of like a mix out solo/Pre2 on another brands digital mixer.
Hope that makes sense. Thanks for your time!
Using the Listen symbol you can listen to both Main LR or any of your 6 Out aux mixes (incl. processing) via the headphone output - including your own (see image).
However, the CQ does not seem to allow PFL for the outputs, only AFL.
And, in case you were thinking along those lines, you cannot create an additional 8th mix.
If you do not select an input or output channel to listen to, you will automatically hear MAIN LR.
There is a setting for the headphone so you can set it to listen to the individual channels, cant remember where you find it though, probably under custom somewhere.
Cheers
David
