Pink noise L/R stereo matrix
Looks very weird that you cannot send pink noise on the left or right only on a stereo matrix.
stereo matrix AND stereo aux… i patch the oscillator on a channel as a workaround to this flaw
Can’t you enable the signal generator on the matrix, and then use the pan of that matrix to determine L or R? Didn’t check it. It’s just a thought.
Best regards,
Rob
Nope, there is no pan on both stereo matrixes and main.
The only workaround is the one suggest from barao, having the pink noise on an input channel
As far as I remember there is a pan, hidden in the routing screen. You might want to check that out.
I really hope I’m not wrong on this one…
Rob
I just checked and you’re right! The pan knob is not working but you can do it from the routing page after selecting the matrix. It is still a workaround but it’s ok : ) thank you!
