PL-10 on DualRack
Now that PL-10(remote control) has be set an each functions on DualRack system
the switch function is be wrong.
Dual Rack System: Surface:R72^iDR16(Master)-iDR16(Slave)
PL-10 to be connected on “Slave Mixrack”
The switch to be set as Input mute functions(65ch-70ch)
As the switch that to be set as Input mute 65ch is be pushed
LED for 65ch and 66 ch is be lighted at the same time.
As also push the switch for 66ch, light LED for 66ch and 65ch.
It seems each channels from 65ch-70ch(65/66 67/68 69/70) might be link.
It is working as followes below
From 71ch-128ch on slave mixrack and 1ch-60ch(except stereo channel) on Master mixrack.
Your advice for PL-10 setting on dual rack would be appriciate.
Yosuke Asahina
Hi Yosuke
are the channels you are using in a Stereo configuration? Or are these channels ganged together with the mute function linked? Or ist it possible you have mapped the same function to 2 PL-10 buttons?
If not
Please contact A&H Technical Support who will be able to help resolve your issue.
Please include a show file and information on exactly how you have your system connected and setup.
Regards
Sam A&H
Thank you for your reply.
Our system on iLive DualRack is used without that setting you point out.
I appreciate your cooparation every time.
We will contact A&HSupport.
