Planned SQ5 setup with ME-500s
Towards mid-year I’m planning on getting a SQ-5 mixer with either two DX168 or DX164-W expanders.
This is for a semi-permanent venue, the two expanders to be mounted stage left and right.
I currently have a single ME-1 and am planning on adding four or more ME-500’s.
In the “Supported SLink Port Connections” document, it explicitly shows: SQ5 → AB168 → AB168 → ME-1/500 etc
But it doesn’t specifically show: SQ5 → DX168 → DX168 → ME-1 → ME-500 etc?
Can I assume that the second scenario will work?
Also, just to complicate things, could I put a PoE switch after the last expander for star connecting the ME’s?
Hi Gary,
you can´t connect a DX168 with the ME-1. The DX works on 96kHz and the ME-… doesn´t support it. So you can only choose for example the AR2412 that works on 48 kHz for work with the personal Monitor System from A&H! This is a very big angry trouble from A&H !! Bring us new Mixers with 96kHz and Stagebox but not working with their Personalmonitor Mixers…that´s very fine ! :frowning:
Hi Gary,
sorry my english is not so good. Maybe you understand my post wrong, because i write it´s not work on 96kHz ? Of course you can connect the ME-… Mixers directly on a SQ Mixer, that will work. But not at the DX168, because not possible to connect there.
have a look here
https://www.allen-heath.com/ahproducts/sq-6/#tab4
and download the document “SQ-6 V1.1.0 SLink Connections”.
there is very nicely described what works.
As Gogos pointed out, the Personal mixers run on 48kHz (dSnake) whereas sLink (DX-- products) run at 96kHz only. [ACE & Dante & Waves Soundgrid are ToBeDetermined (kHz)]
At present, you can have a 96kHz digital snake [NO ME’s] OR 48kHz digital snake & ME’s.
In the future the sLink expansion card will allow for a digital snake & a ME1 connection [local (sLink) port running as dSnake (48kHz) & expansion card (sLink) running at 96kHz for DX168 or DX32 or DXHUB].
I applaud A&H for the interconnectivity of the SQ-x series of boards, but I think a 96kHz digital snake option that works with ME’s is a blatant omission [perhaps it is in development].
I really think an extra port (ME_Link)=[dSnake] on the board would have been a better idea, putting the ME1/500/Hub on their own dSnake network at all times [either that or the new sLink card should have two ports on it, one sLink (96kHz and one dSnake (48kHz)]. They might come out with a sLink card for the ME-U with pass through that would be perfect. I really dunno how they’re gonna do it but it needs to be done for those that want personal mixers & dLive/96kHz preamps. Otherwise 96kHz is just another gimmick like everything else is these days.
My thread talks about this.
https://community.allen-heath.com/forums/topic/sq-me1-500-connectivity
Cheers for the input guys, thanks!
It does look like each of the DM0, DM32, DM48 and DM64 all have dedicated ME-1/500 48khz ethernet port. All options I suspect are fairly expensive!
When I went to the A&H Qu-series, I was really surprised at how much better the mic pre’s sounded and how much hotter I could run signal into them.
I am drawn to the DX168 (or DX164-W) as I am assuming they use dLive class pre-amps, A&H’s top of the line pre-amps.
Has anyone done any listening tests / comparisons between A&H’s Qu, SQ and dLive pre-amps?
I was just talking to my buddy about the x32 vs dl32 preamps.
Last reply by Tim:
3rd reply by Tim:
Basically you can’t separate the analog preamp section from the rest of the board. The dLive is the best technically (objectively) sounding console on the market today; that’s not JUST because of its preamps.
Good, Better, Best. [Qu, SQ, dLive]
Yes DX168 uses the dLive preamps @ 96kHz. It will sound better than QU; but it’s just a PART of the ecosystem.
Good points Lightingman117.
Thanks for the links too.
I forgot to mention that the 96bit accumulator is a big part of the dLive’s sound quality and SQ shares it.
Info on accumulator & floating vs integer math
That makes a lot of sense, thanks.
I’ve gone ahead and added some ME-500’s to my current Qu-SB setup.
Will watch with interest as the time draws near to add a SQ-5 into the mix.
