After setting up the SoftKeys for SQ-Drive Record/Playback, I thought it might be nice to have a little feedback from the SoftKey itself.
Here’s my idea:
SoftKey for Play/Pause:
Play - light is on solid.
Pause - light blinks.
Softkeyfor Record:
Arm/Record - light is on solid.
This way if you press the Arm SoftKey, it will light solid and the Play/Pause SoftKey will blink. I know it shows in the screen, but adding it to the button would be nice!
I don’t think putting them all on one is a good idea. If you ARM and then change your mind, your have to RECORD before you can stop. The ARM and RECORD on the same button might be ok.
I’ve a little 2 track recorder that has the 3 functions on one button, which I find annoying for that reason. I guess on the SQ though, the 3 individual buttons are available via the screen if you do want them. I would for one always want to press Arm & check levels are reasonable, if at all possible before starting to record.
I have been using a qu16 for a long time and have used the recorder a lot. the soft buttons light up and flash.
I was amazed when I used the sq recorder for the first time and the buttons remained dark.
Along these same lines the SQ Mix APP does not have anything close to the Q Drive level of control that the QU Mix APP does. the SQ Mix APP is about what the QU Mix APP was when it first came out.
