Record some tracks to the SD card. That will show you how to format them. If CQ is like the other A&H mixers, there is a very limited spec as to what will play.
That’s just for playback, though. You’ll need to go USB to a DAW to do multitrack overdub recording, which is what you’re asking about. Reaper is cheap and excellent.
That is so unfortunate and a huge missed feature. Just to clarify what I am trying to do is exactly same as below:
I was attempting to move to CQ from the brand in the video. So is importing file to a Project not possible in the CQ? Hoping to not have to connect another device such as a laptop to do this step.
I wanted to use tracks recorded on another device. I made sure they were 48KHz, 24 bit and named…
01XYZ
02ABC
03DEF
etc.
(obviously letters can be anything - KICK,VOX etc.
And replaced the WAVs in the CQ-MT001 folder which the desk had created for me on a short recording.
I went through quite a hassle trying to get files I copied to the SD card to play. I found that Broadcast Wave files created in Nuendo were a NO GO! And no way to fix them other than to recreate them in standard Wave format. The Bwave files would actually cause the recorder function to lock up, or show as in use even while not, and become unusable without a power cycle. After I recreated the files as 48k/24bit Wave, they worked fine. There is a section in the manual that describes the folder structure and naming requirements.
Not being able to overdub to empty tracks in a huge bummer for an otherwise incredible to me so far mixer.
