Please add variable slopes to the shelving filers on the Aux and Main outs and allow for linking the fader level of an Aux to the fader level of the Main
  1. For those of us running Aux Fed subs, it would be great to have a finer level of control over the cross over region. On the Ui-24 for instance, you can select 12, 24 or 36 db/octave slopes for the hpf/lpf.
  2. It would also be great if we could directly link the fader level of, say AUX 6 to the fader level of the Main LR. It seems like we can use a DCA and use the DCA Master to control the levels of the AUX and Main LR. … but that burns one of too few already DCA’s
Thanks, Mal
Both are good ideas. I think they would get more votes if you split them into the two separate suggestions they actually are.
Couldn’t you just roll off what you wanted with the Graphic EQ?
Unfortunately not, because a GEQ has a completely different functionality.
You can only attenuate or boost certain fixed frequency bands.
It has neither high-pass filter nor a low-pass filter, and also neither adjustable frequencies nor variable slope, which was the actually suggestion.
Coming here from ProSoundWeb…as we discussed, I need the same thing with adjustable slopes for crossover purposes for aux fed subs.
