Hi everyone! Our church was recently given this MixWizard WZ3 16:2 mixing board, which is rad, but it looks like it has an issue, and I can’t find any mention of it around the internet - I’m hoping one of you may have the answer!
Here’s a video of the issue: https://youtu.be/RNrMU22Btm4
So, we noticed a faint popping sound and started to investigate. If you crank a channel/output up it gets louder. Then we noticed the popping sound happening in sync with a light in the effects section, and if you turn the effects up, the pop gets louder. If you press the SEL button to switch through the effects, nothing happens - you can’t cycle through them.
I’ve heard the board can be “reset” by starting it up while holding the SEL button in, but this hasn’t worked (possibly because the button doesn’t respond).
Otherwise, all the channels, etc seem to work.
Anyone ever had to deal with this kind of issue? Is there a repair that can be done? What can I try?
