There is a two level save with scenes and shows. that is, when you edit a scene and store it, you also need to overwrite the show for the scene to be actually saved. (this is fine however a prompt to auto save the show from the screen store would be nice)…
So here is issue:
When you over-write a scene it resets the scene name and then you need to recreate it.
How to reproduce:
Create a show with a bunch of scenes.
( it now blows the scene name away – and sets it to ‘scene N’  where N is the scene ordinal number.
- if you now recall the scene it seems to blow the config away.
The workaround is too
At this point the scene is updated.
If you don’t do the workaround you loose random scenes (not just the one you tried to overwrite). Which is particularly irritating
Carl.
              Hi cctrieloff
this was an issue in old firmware.
are you running the latest firmware v1.02?
Regards
Sam A&H
              I’ll confirm this weekend. I believe I am.
Carl.
              Sam,
I have checked and I’m on V1.02. The issue can be repeated every time.
Carl
              Hi Carl
I Cannot reproduce the scene name being lost in the latest firmware v1.02.
Scenes are saved within shows therefore every time you update your scenes you will also need to overwrite your show for the scenes to be up to date.
Please contact A&H Technical Support if you still have issues They will be able to directly support you on resolving your issue.
Regards
Sam A&H
              Yes, I figured out you need to save the show, but even so I can reproduce it easily.
Try this.
Create a show.
Create 3 users.
Create 3 scenes.
Now don’t assign a show to one user and admin.
Recall Admin.
edit something, store the show.
swap users / force an auto scene recall.
swap user to one without a scene recall.
go to scenes tab, and select the first scene – (if you select one scene, then other, then the first one again it works. This is now my work around)
select store.
BANG – first scene is blown away & 3rd scene is corrupted.
Carl.
              Hi Carl
I am afraid i had trouble following your reproduce procedure.
Please contact A&H Technical Support and submit a support ticket to report the issue. Also a video of the reproduce procedure would be useful if possible.
https://www.allen-heath.com/uk/support/Pages/support.aspx
Regards
Sam A&H
              I’ll find a time when I can call and sit in-front of the desk to walk support through it,
regards,
Carl.
              Hi Carl
From further investigation we have now replicated this issue and a few other variations that can cause scene names to be reset. Well spotted this will be fixed in a future firmware update.
Regards
Sam A&H
              Great, I was planning to find some time next week to call support - one less thing to do
thx
Carl.
