Post EQ / compression on mixes mix1 mix2 etc. (QU-SB)
Sure I’m missing something: the EQ and compression affect the LR mix, but I can’t figure out how to get the mix1, mix2 etc. to have the preamp/eq/compression as well. This is QU-SB controlled with Qu-Pad app, and the detailed documentation is for the consoles, which are just enough different to confuse me completely. Help appreciated thanks!
Select mix, tap arrow to the right under “tap to name”, channel source, succes
Good luck !
Giga
