Post Fader Insert
I need the ability to switch the INPUT CH “Ins B” point to Post Fader in Avantis.
This is very important when operating the Dan Dugan Sound Design (DDSD) AutoMixer (Dante/MADI/WavesSoundGrid) insert.
Especially in DDSD Model M and Model D, there is a function to mix and output the sound processed by each group in the routing of the main unit, which contributes to a significant reduction of console resources.
https://dandugan.com/products/
I usually used the FaderFollow setting on the AMM in the SQ, but I could not PFL when the Fader was turned down to the bottom and the LED Meter did not light up, so I had to remove the assignment once from the AMM to work on replacing the wireless mic and check if the mic was broken The only way was to remove the assignment from the AMM.
