Post Fader Metering
Hello,
I would like to have post-fader metering in the custom meters section without loosing quick and easy access to pre-fader metering and gain-reduction-metering.
Direct Input-metering is important to setup and monitor gains correctly, to avoid input-clipping, to “understand” dynamics. Gain-Reduction-Metering is important to show the current activity of the dynamics processing. Post-Fader-metering is the visual feedback of the balance in the mix. If it does not fit what you can hear and/or what the current fader-positions suggest, this often gives indications about wrong EQ or dynamics settings (or bad song arrangements).
Thank you,
Tun Schlechter
