Pre or post fader option for the headphone outputs
It would be great to have the option to choose pre or post fader for the headphone outputs. This is mainly so I can monitor the Main LR output in the headphones even when the fader is low or muted. I have the workaround which is to create a stereo mix that emulates the Main LR mix so that I’m able to have the Main LR master down or muted and be monitoring the Stereo mix but it means I have to sacrifice 2 of my output channels.
you can still use the listen button on the main LR, which should do the trick.. worth a try if that passes full signal even when the fader is down..
As far as I know (and judging by the block diagram), mixes can unfortunately generally only be listen after-fader, which is why the desire for a PFL option for mixes on the CQ has frequently been voiced here.
