Pre/post options on channel strips
Have pre/post settings available in the selected channel overview. Also a global pre/post selection per bus would be nice.
it is already there…
Where? I’m on a C3500 and dont see it anywhere on the channel.
you have a dedicated button on the surface for Pre/Post, pressing this button views the pre post setting for selected mix,
pressing Pre/Post and Select changes pre post for the active mix
the routing screen uses different colours for pre or post
in the channel view it makes no sense
Hi Steffen is right.
Maybe to clarify a bit:
Pressing the green “Pre” button on the surface shows you the current state of every channel dependent on the mix you chose (f.e. Aux 1).
Holding Pre and pressing Sel on a channel changes Pre/Post on the channel, holding Pre and pressing Sel on a Mix-Master chancels Pre/Post for the complete Mix (Aux).
It’s simple and fast and it’s there since early iLive-days (also on GLD and dLive).
Cheers
pre or post is also indicated on the routing screen with different colors
but it’s not visible if the send is all the way down
and it’s written in the strip display
