Pre-Sale question - how to connect
Hi.
Was an long time ILive user - and currently searching for a new System.
I am interessted in buying an DM32 along with and IP6 and an IP8 - but no surface.
So my question is this:
How do i connect the IP6 if this should stay on stage next to the MixRack and then run a single CAT5 Cable to FOH to connect an
PC for use with Director Software and the IP8 (for having a couple of faders).
How would the system be connected - and is this even possible (with ans single CAT5 Cable?)?
Thanks in advance.
Albin
Hello,
FOH - Director & IP8 go into a switch (Switch-If you don’t want to use the IP power supplies you need a POE+ switch for the IP8)
1 CAT5 Cable from the FOH switch to Network Port 1 on the DM MixRack.
Stage - IP6 Into Network Port 2 on the DM MixRack.
Support A&H.
Ok, thank u.
I had a look at Director and tried to find how to configure the IP8 offline.
Is this not implemented yet or did i just not find it?
Albin
Yes, you can configure IP Controllers offline in Director, from V1.30.
Information and system examples available on the A&H website -
https://www.allen-heath.com/ahproducts/ip6/
https://www.allen-heath.com/ahproducts/ip8/
