Pre Trim for Direct Out
I do a lot of multitrack recording for a variety of shows that come through our building. Currently, there’s no way to adjust the trim without affecting the direct out feed. This is fine if you set up a socket-for-socket split on the board, but if you want to set up the board in advance and patch the channels once everything’s plugged in where it’s going, it’s a pain, as you then have to separately go through and patch your socket outputs. It would be easier if the option to pull direct out pre-trim existed. I wouldn’t get rid of Socket, as I use this to send non-show essential audio (lobby sound, etc.) onto our Dante network without taking up an audio channel.
