Problém s nastavením zeslabování hudby když se mluví do mikrofonu / Problem with setting the music to fade out when speaking into the microphone
Dobrý den mám problém s nastavením zeslabování hudby když začnu mluvit do mikrofonu. Hudbu mam zapojenou do linku 13/14 jako stereo link funkce AMM mi neumožní to nastavit. AMM jde pouze nastavit jen na jednotlivý odkaz. Když chci nastavit ručně Sidechain Source tak tato možnost je v mixu nedohledatelná. Mohl bych poprosit o radu jak to udělat nebo umožňujete vůbec mix aby se to dalo nastavit bez AMM.
Bude to mix umožňovat pokud vyjde příští Firmware.
Je to pro mě dost podstatná funkce a myslím si, že pro všechny co dělají svatby, oslayv atd.
Děkuji za odpověď.
S pozdravem Jaroslav Vacek
Hello, I have a problem with setting the music fade when I start speaking into the microphone. I have music connected to line 13/14 as a stereo link, the AMM function does not allow me to set it. AMM can only be set for a single link. When I want to set the Sidechain Source manually, this option is not available in the mix. Could I ask for advice on how to do it or do you even allow the mix to be set without AMM.
The mix will enable this when the next Firmware is released.
It is a pretty important function for me and I think it is for everyone who does weddings, celebrations, etc.
Thank you for the answer.
Best regards, Jaroslav Vacek
Your observation is not a bug, as AMM isn’t designed for this, nor would it be particularly well-suited for it.
(Couldn’t you try it by simply plugging your cables from 13/14 into the combo jacks of two with AMM usable inputs?)
What you’re missing is a ducking function, and there are already several feature suggestions for this, such as the one at the link.
However, A&H has already admitted that they (still) don’t know if it would even be technically possible to implement.
And when they write something like that, it’s usually not a good sign pointing towards “yes”.
use mono music on one input and try again with AMM.. or you could set Left and Right Panned without them being stereo linked.
AMM je asi jen pripraveo pro mluvici mikrofony.. Spoken word.
