Problem using the Qu 24 usb 2 socket
Trying link our QU 24 to a computer via the type B USB socket on the mixer to try and run a speech output into “Breeze Translate”
Currently I can’t get the computer to see anything from the mixer. Anyone had any experience of using the Type B usb socket
You’ve installed the driver? Qu Windows ASIO™/WDM Driver
Hi, yes we’ve installed the drivers so not sure what to do next. Any help would be appreciated.
Take a look at videos like this:
Also, check the “USB Audio Interface and DAW Control” section in your Reference Guide (page 78?) and look here as well:
You’ll need to go into the IO set up menu under USB and assign that speech channel input or a mix that it is on to the needed track/channel on the USB that the computer software wants to see as an input.
Thanks for everyone’s help on this.
