Hi, i’m Adrien
I’m a new Aventis Solo user and I have a problem.
My Main LR is patched to the GX48 on outputs 15/16.
My inputs 15 and 16 are connected via SLink to inputs 15 and 16.
The issue is that I have no control over the faders for inputs 15 and 16 — the signal is sent directly to the LR bus, bypassing the faders. However, processing (EQ, dynamics) still work but not the mute. The fader has no effect on the signal level.
If I assign the Main LR to output 16 and use input 15, then I do have fader control. But if I use input 15 and output 15 as Main LR, I lose control again. I don’t understand why this happens.
I’ve checked Tie Lines and Direct Outs, and nothing is patched there.
Can anyone help me?
