Problems wit Analog Insert on SQ6
Hi to everyone, im user from sq6, i like to insert some of my analog compresors.
Example, a bss to my vocal channel or an old drawmer to my Kick and Snare.
I cant figure it out, i try al the combinations on the insert button without succes.
I miss something? Can you help me explain me the procedure?
Whit waves and plugins no drama, but whit hardware its imposible.
Thanxs!
Hi
Did you set correctly the send and return in the insert set up page ?
You need to assign the right socket you want use.
Check page 26 in the manual to get more info :wink:
Have you ensured the insert is set to analog and that the physical input/output connections aren’t double assigned to local inputs?
