Problems with FX1 and FX2
I’m running a new Avantis and I try to setup my show. For me to rehearsal I play back via Dante (64ch card).
Problem: FX engine 1 and FX engine 2 generate a pulsing signal. All other FX engines run correctly.
  • it happens only with all kinds of reverbs. Other effects run correctly. The noise is different when I change the parameters.
  • Mute FX send and/or FX return: no change
  • unroute FX send and route an AUX as send: no change
  • a feedback can be excluded
any ideas or solutions?
Can you try recalling a template show to see if it’s the same? FOH for example
Is the Dante card clocked to the mixer?
The problem is solved: the FX-card was defective. After the provider has changed the card, the desk did what I expected. Thank you anyway!
I used to have this problem too
