Process "Current Cue List" not saved in show
Hello,
When working with scenes there exist two options:
  • process the scene list
  • process the current cue list
I experienced, that when the current cue list shall be processed, this option is not saved within the show.
So each time the show is recalled or the GLD is booted, the option in the scene manager is set to “All Scenes” although
the option has been set to “Current Cue List” when the GLD was shutdown and the “Current Cue List” was set when the show was saved.
This leads to serious mistakes when you forget to change the option before starting the show, as scenes are not recalled in the order
defined by the cue list.
Please change this, as also that making safes for the strip assignments are not SAFE. You have to save each scene again when a strip is added although the assignment should not be recalled from the scene.
Is there any solution for this problem…we are waiting…
